Results 1 to 2 of 2
Thread: ETAP Creation of Single Line Diagram
  1. #1
    Join Date
    Nov 2017
    Philippines
    Posts
    1
    Hello,
    I have been trying to create a single line diagram
    Name:  SLD Etap question.jpg
    I have the following questions. Please help. huhu
    (1) Where can I found a Resistance Resistor Starters for Medium Voltage in ETAP?
    (2) Where can I found the Load Break Switch? (Non-Fuse Type)
    (3) Where can I found Disconnect Switch?
    I really appreciate who will help.
    Thank you in advance
  2. #2
    Join Date
    Jul 2006
    SE USA as far as you can go
    Posts
    2,688
    The starting device is tab under the motor editor,
    A load break switch is just the regular switch symbol,
    And the disconnect is same as switch.
    "Just because you're paranoid, doesn't mean they're not out to get you"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
