User Tag List
Results 1 to 2 of 2
Thread: Grounding Table Question
  1. #1
    Join Date
    Nov 2018
    NYC, NY, USA
    Posts
    3
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello, I am having a hard time understanding any scenarios where you would use the 250.102 table to size the ground conductors running along the phase conductors instead of the typical 250.122 table. I believe i have a read that the secondary side of the transformer before the disconnecting means since its not in the same enclosure as the SDS would require 250.102 table to be used to side the ground conductor (acts as the supply side bonding jumper). What about a generator as a SDS? Would this be 250.122 because disconnecting means is in the enclosure? Any other scenarios?
    Also, is a GEC and EGC required on all SDS over 1000kVA?
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,855
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    duplicate
    If you don't think too good, don't think too much.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
