User Tag List
Results 1 to 3 of 3
Thread: New Feature for the Forum
  1. #1
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,006
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    We now have a feature that can alert another member that you responded to their thread. This is not meant to be used regularly but rather on an occasions. For example, if there is a thread that was started yesterday and no one has posted in it for a day and you have some good info. In this case you may want to give the poster a heads up that you have responded to them, in case, they miss it.
    How do you do it... Basically at the end you would type the "@" symbol and the username. I will direct one to myself but I don't think it actual works to yourself but you can see what I did. @Dennis Alwon
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,006
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    BTW, the person should get a notification in the upper right- where your pm notices are.
  3. #3
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    23,950
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
