Results 1 to 2 of 2
Thread: amp/voltage recorder
  1. #1
    Join Date
    Mar 2003
    Wisconsin
    Posts
    988
    I'm looking for an inexpensive voltage/amperage recorder for 3 phase systems, up to 600V (480/277). Does anybody have any suggestions?
    Inexpensive <= $1500
    Thanks,
  2. #2
    Join Date
    Feb 2003
    Alabama
    Posts
    2,668
    Re: amp/voltage recorder
    Emon Has a digital recorder that will give amps,
    kw and kva if needed. uses 3 clip on CTs and pts.
    Check at Emon.com for info. AS I recall they are
    not expensive.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
