Tap Rules
Sparky555
Help would be greatly appreciated from anyone with a working understanding of tap rules. The situation is as follows:
It's a single phase residence with a 400A service. There's a fused 400 amp disconnect by the meter pedestal. Inside the home each 400A wire is spliced with a pair of 200A wires. One set goes to a 200A fused disconnect for hot water baseboard heat, the other set goes to a 200A MB distribution panel. I'm assuming the 200A wire is allowed to be fused at 400A by a tap rule. The 200A wires are under 10 feet long.
My question is:
Am I allowed another tap on this 400A wire to another 200A distribution panel if the load calculation comes in under 320A?
Dave
infinity
New Jersey
Journeyman Electrician
Sparky555 said:
My question is:
Dave
Yes this is permitted. Why are you limiting yourself to 320 amps?
charlie
Indianapolis
stickboy1375 said:
80% silly, you can never use that last 20%.... :grin:
HUH? 215.2(A)(1) General. Feeder conductors shall have an ampacity not less than required to supply the load as calculated in Parts III, IV, and V of Article 220. The minimum feeder-circuit conductor size, before the application of any adjustment or correction factors, shall have an allowable ampacity not less than the noncontinuous load plus 125 percent of the continuous load. ;)
infinity
New Jersey
The load calculation would already include 125% so your permitted calculated load is 400 amps.
