Results 1 to 5 of 5
Thread: Wire wound resistor wattage identification by dimensions
  1. #1
    Join Date
    Aug 2003
    Posts
    3
    Where can I find a chart or other method to identify the wattage of a Wire Wound Variable Resistor?
    The label is: OHMITE DIVIxxHM NO. 0568 250 ohm xx46 (xx= illegible characters). It is 4" long x 1/2" outside Dia. x 1/4" inside dia.
    I am replacing it with a slightly larger wattage rheostat for convenience and because the original ceramic tube broke when it blew.
    I've checked a few distributors and other elec. sites to no avail. Also looked in a few basic elec. reference books. Any ideas.
  2. #2
    Join Date
    Feb 2003
    Posts
    3,172
    Re: Wire wound resistor wattage identification by dimensions
    Look for one with the same resistance and physical size.
  3. #3
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,467
    Have you tried the Ohmite website?
    http://www.ohmite.com/cgi-bin/showpa...uct=210_series
    It's now the 210 series and is 50 watts for that physical size.
  4. #4
    Join Date
    Aug 2003
    Posts
    3
    Thanks Bennie. The situation is that my customer brought me the broken part instead of a service call.
    [ September 07, 2003, 09:06 AM: Message edited by: macon ]
  5. #5
    Join Date
    Aug 2003
    Posts
    3
    Thanks Hbiss. I have the exact replacement P/N and the rheostat P/N from the Ohmite link you provided.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
