Results 1 to 3 of 3
Thread: Table 220.3(A) General Lighting Loads by Occupancy
  1. #1
    Join Date
    Dec 2004
    Travel to Jobs. Home in Michigan, now in Arkansas
    Posts
    12
    I am designing new lighting for a Squash Club. It has 7 courts plus viewing gallery, showers, & lounge. The fixture types have been chosen to match international standards for lumens required for the courts.
    This type of Occupany is not defined in Table 220.3(A). If an Occupancy is not defined can I use the actual fixture VA"s?
    Annex D, Example D3, Store building states that I must use the larger of the acutual connected load versus the lighting loads shown in Table 220.3(A). If the occupancy is not listed, than I should be able to use the actual, correct??
    I need guidance for my load cal's for which type of occupancy.
    Thank you,
    PDRigozzi
  2. #2
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,783
    Re: Table 220.3(A) General Lighting Loads by Occupancy
    Since this facility has squash courts, why not use the 2 VA per ft^2 allowed for “court rooms”? (Sorry, couldn’t resist).
    When I get involved in a project for which the occupancy is not listed on Table 220.3(A), I try to find the nearest logical match. In your case, I would use the 1 VA per ft^2 allowed for “auditoriums.” Then I would calculate the actual VA for the selected fixtures (using the fixture rating, even if the selected light bulbs use a lower amount of power). I would submit as my final calculation whichever of these two gives the higher load.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  3. #3
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,724
    Although the NEC has lighting loads per sq ft, many states have energy codes which are much lower per sq ft than the NEC for what is acutally installed. You have to size the service per the NEC and install the lighting per the energy code.
    Moderator-Washington State
    Ancora Imparo
Posting Permissions
  • You may not post replies
  • You may not edit your posts
