David Butler
New member
what is wrong with installing PVC inside a wall for low voltage cable instead of EMT? Is it OK to use PVC as a sleeve with fire stop instead of EMT. These questions are for hospital installation.
How would that make a difference when the OP seems to be dealing with VD FA ect?roger said:Are you asking about Patient Care Areas?
Roger
chris kennedy said:How would that make a difference when the OP seems to be dealing with VD FA ect?
