Go Back   Mike Holt's Forum > Electrical Contracting and Estimating/Management
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Closed Thread
Thread Tools Search this Thread Display Modes
  #1
Old 06-04-2003, 12:46 PM
david777 david777 is offline
Junior Member
Default Conduit in concrete
[ June 05, 2003, 08:22 AM: Message edited by: david777 ]
  #2
Old 06-04-2003, 08:25 PM
Nick Nick is offline
Default Re: Conduit in concrete
No it is not a violation. High rise condos are usually constructed of poured in place concrete and full of conduit (usually smurf tube) in the walls and decks. The deck heights in condo’s and hotels are very low not leaving much room for conduits in the ceilings.
  #3
Old 06-04-2003, 11:39 PM
jrdsg jrdsg is offline
watch for low-voltage & communications cables in core line [cast-in-place] installations also. it is important in high-rises and other slab-floor installations to verify that the concrete you are about to core or hammer-drill through does not contain cable. unfortunately once a communications cable is severed in a core line it is often necessary to abandon the cable run and install a new cable, or to enlarge the hole significantly to install a functional splice point. unlike conduit, core line is notoriously difficult to pull through a second time, since it often contains more bends than a similar conduit path. we have had 200-pair telco cable, fiber-optic cable, and other wiring damaged by other trades thusly. never assume that a piece of concrete slab is unencumbered by hidden wiring.
Closed Thread
taking exam?  Forums
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
