Go Back   Mike Holt's Forum > Electrical Contracting and Estimating/Management
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Closed Thread
Thread Tools Search this Thread Display Modes
  #1
Old 03-02-2003, 11:04 PM
bwieland bwieland is offline
Junior Member
Default different voltages between switches in same enclosure
does grouping two switches one at 120v and the other at 277v both have 600v insulation violate 404.8 (b) or any other part of the nec
  #2
Old 03-02-2003, 11:52 PM
don_resqcapt19's Avatar
don_resqcapt19 don_resqcapt19 is offline
Default Re: different voltages between switches in same enclosure
Both systems are grounded systems, so there will be voltage between the two hots. The amount of this voltage will vary based on the phase relationship between the two hots and the amount of phase shift between the two systems. Most combinations will result in a voltage exceeding 300 volts between the two hots.
Don
__________________
Don, Illinois
"And whether you're an honest man, or whether you're a thief, depends on whose solicitor has given me my brief." B Franklin
  #3
Old 03-02-2003, 11:55 PM
harold endean harold endean is offline
Junior Member
Section 404.8 (b) does not allow 2 switches to be side by side and have more than 300 volts between them What you most often see is a 4" square box with a divider in there to isolate the 277 volt switch from the 120 volt switch. Either that or you can just install 2 different boxes with each switch having only their own voltage in each box.
Closed Thread
101 Rules Forums
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
