Go Back   Mike Holt's Forum > Electrical Contracting and Estimating/Management
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Closed Thread
Thread Tools Search this Thread Display Modes
  #1
Old 05-04-2003, 05:04 PM
jro jro is offline
Default pricing and bidding
I am new to the electrical contracting business, my question: Example for service work say I charge $45 for Electrician and $20 for helper + materials. Now on a bid job I estimated a job for 95 hrs, do I use this calculation 95hrs x $45 = labor price? I plan to send 3 men to do the job 1 electrician 2 helpers, I use i2 electrical price guide to get my labor units and material pricing. Stuck on subject
  #2
Old 05-04-2003, 05:33 PM
bphgravity bphgravity is offline
Default Re: pricing and bidding
In my opinion, there is not a wrong way to bid as long as you make money on the job. There would nothing wrong with calculating total hours with your higher labor rate. You could also divde the total hours by total employees, and then calculate cost for each one. (95hrs / 3 = 32hrs, 32 x 45 + 32 x 20 + 32 x 20 = total labor rate) Kepp in mind, this method has cut your labor profit completely in half! An average method works well also. Good Luck!
__________________
Bryan P. Holland, ICC Electrical Code Official
CBO, Plans Examiner, Inspector, Instructor
Secretary - IAEI Florida Gulf Coast Division
Secretary - BOAF Gulf Coast Chapter
  #3
Old 05-04-2003, 06:22 PM
roger's Avatar
roger roger is offline
Bryan, makes a good point in breaking it down into electrican hrs + helper + helper.
This isn't what you want to do, but your competiton most likely will, which will take you out of the picture. You will probably need to reduce your mark up (overhead and profit) to. Service rates normally can't be carried over into a bid or longer term jobs.
You have to consider that if planned right, the job you are bidding should have less non productive time than a typical service call, somewhat evening the playing field.
Roger
__________________
Old 05-07-2003, 05:38 PM
jro jro is offline
Thanks, all and everyone for your input, its good people like you that make life alot easier.
Closed Thread
CEU Banner Home Page
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
