stuckndsticks
I have an existing soft start running a 200 hp motor a couple of times a week. Can I install a 200Amp fused disconnect and run a 125 HP motor from the same starter? This motor is also a part time motor. I plan to interlock the disconnect as well as installing separate start/stop buttons for the new motor. A new run relay will also be installed and interlocked to prevent both motors from running.
