Go Back   Mike Holt's Forum > Grounding versus Bonding
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Closed Thread
Thread Tools Search this Thread Display Modes
  #1
Old 02-28-2003, 09:09 AM
al's Avatar
al al is offline
Default Ground Rod Inside Building
Is there any Code requirement that a supplementary rod electrode cannot be located inside a building? Example would be a house with a crawl space with a dirt floor.
  #2
Old 02-28-2003, 09:32 AM
dereckbc's Avatar
dereckbc dereckbc is offline
Default Re: Ground Rod Inside Building
I do not believe there is any restriction that says it has to be outside. I see them inside of commercial and industry.
  #3
Old 02-28-2003, 09:33 AM
charlie's Avatar
charlie charlie is offline
No problem, sorta. The Code is a permissive document, in other words, if it doesn't say you can't, then you can. In the case of a ground rod in the crawl space, how do you deal with the dryness issue in the future when the soil dries out? I know the rod extends down about 10 feet (length of the rod plus the depth of the crawl space), but I would think it would still be dryer than the surrounding area. Remember the Code is a minimum standard. I would not feel comfortable with the idea. :(
__________________
Charlie Eldridge, Indianapolis, Utility Power Guy
Responses based on the 2008 NEC, unless stated otherwise.
  #4
Old 02-28-2003, 09:34 AM
bphgravity bphgravity is offline
There is no restriction as long as you meet the requirements of 250.53(D)(2) and (E), (G) if supplementing underground metal water pipe, or 250.54 and 250.118.
__________________
Bryan P. Holland, ICC Electrical Code Official
CBO, Plans Examiner, Inspector, Instructor
Secretary - IAEI Florida Gulf Coast Division
Secretary - BOAF Gulf Coast Chapter
  #5
Old 02-28-2003, 09:59 AM
al's Avatar
al al is offline
Charlie: In this case the rod would be an additional 4' below outside grade due to the crawl space depth and next to the foundation outside wall. Becuse of this I believe the ground resistance would be less in this case.
Al
  #6
Old 02-28-2003, 01:13 PM
karl riley karl riley is offline
By chance I found an answer to this from Charlie Trout (Code Message of the Day) from 2000. He says it is allowed but questions why you would want to direct a lightning strike to that point. He adds that driving two rods might save time rather than having to prove a 25 ohm resistance from the rod in dry soil.
Karl
__________________
Karl Riley
Old 03-02-2003, 11:34 AM
wocolt wocolt is offline
Are we talking supplemental electrode or supplementary electrode there is a difference.
ie, supplemental electode 250.56 and suplementary grounding electrodes and their conductors are not required to comply with the bonding requirements of article 250.50/
Supplementary electrodes are usually used for signal reference 250.54.
WOC
Closed Thread
CEU Banner Home Page
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
