shankarums
New member
Hi All
I am working on Statcom for windmill applications where my statcom operate for reactive power requirement from wind generators.
But I would like to know how a basic statcom connected to bus through transformer compensates reactive power? What is the specs for the transformer such it would transfer voltage from statcom to bus.
Initially i assumed grid as ideal source and connected RL load. For this configuration If add passive type compensators , it works well in case of reactive power compensation.
But If i replace that passive comp with active comp like statcom(VSC) thro Transformer, I couldnt get that compensated, instead total reactive power increased. I have taken simple 1:1 Transformer. Thats how voltage from statcom output compensates the reactive power requirements?
should we give statcom output directly to bus instead of transformer?
Anybody can explain this and also i need continuous support for me to complete my work finally with reactive power compensation using statcom for windmill applications.
Suggest how to proceed? Since i am starting from scracth
