Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Harmonic Currents In Single Phase
  1. #1
    Why is it that harmonic currents are not such a big problem with Single phase and they are on three phase? What happens if you have someone with 5 computers and non-linear loads in a residence will this be a problem?
  2. #2
    Join Date
    Feb 2003
    Posts
    638
    Re: Harmonic Currents In Single Phase
    In single phase the neutral will not be carrying any more current than the hot.
    In three phase with one neutral, the harmonics build up on the neutral due to the fact that 180Hz, etc does not cancel between the phases, so the neutral can be carrying more current than any of the phases. One remedy is using 3 neutrals, so that it is like 3 single-phase circuits. The other remedy is a larger neutral.
    To prevent harmonics check with Dereck!
    Karl
    Karl Riley
    Join Date
    Feb 2003
    Plano, TX
    Posts
    3,820
    Nothing happens with 5 computers in a residence with single phase service.
  4. #4
    Join Date
    May 2003
    Leesburg, VA
    Posts
    7,069
    Durn I love the internet:
    (and all of you harmonic causing end users)
    HDE check this out
    http://www.copper.org/pq/issues.html
    Brian John
    Leesburg, VA
  5. #5
    Join Date
    Feb 2003
    Posts
    638
    Thanks Brian, great source. Tells it all.
    Karl
    Karl Riley
    Join Date
    Feb 2003
    Plano, TX
    Posts
    3,820
    Karl
    I read the white paper and found it informative. However I found thier reccomended solutions a little biased, which they alluded too. All the solutions were copper based, which is what you would expect from the copper industry. What they did not mention was the most effective means such as MG and dual conversion UPS. Just some food for thought.
  7. #7
    Join Date
    Feb 2003
    Illinois
    Posts
    23,352
    dereck,
    They also never talk about the use of true single phase distribution to prevent excessive current on the neutral with nonlinear loads.
    don
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
  8. #8
    Join Date
    May 2003
    Leesburg, VA
    Posts
    7,069
    hde A good book for your library.
    http://web.idirect.com/~a1parts/mw_handbook.html
    Brian John
    Leesburg, VA
  9. #9
    Join Date
    Feb 2003
    Anaheim, California
    Posts
    205
    Just wanted to add a little to the previously made informative posts.
    Yes, there will still be Harmonic Currents involved with a 1 System, but the effects on the Common Grounded (Neutral) Conductor of Multiwire Circuits aren't like those of Polyphase Multiwire Circuits (3 4 Wire Wye Systems).
    The level of Distortion needs to be considered. 10% THD would include an additional 10% Line Current on the 2 Wire Circuit. 20% THD adds 20% more, and 33% adds 33% more.
    On 3 4 Wire Wye Systems using 4 Wire Multiwire Branch Circuits for Loads having 30% THD, the Common Grounded Conductor will be carrying upto (or possibly more than) 200% of the Load Current.
    I have given some very basic, simple descriptions here, but they cover the topic enough to give you more ideas of what to look for in studies.
    Scott
    p.s. - it's been Eons since my last post in this forum! How are all of you?
    Scott35
    Submitted for your enjoyment by:
    Scott "Scott 35" Thompson
    Boring Document Compiler,
    Drawer of Pretty Pictures to Build things from,
    Assistant to the Assistant Cat Servant.
  10. #10
    Join Date
    Feb 2003
    Fl
    Posts
    16,874
    Hello Scott, nice to hear from you again. How's the locomotive world treating you?
    Roger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
