how does one interpret the results of megohmeter tests officially? i usually connect the black lead to a known good ground reference source to begin with.Then i open the wire or the circuit to be tested.then i crank up the megger.it is my understanding that this test measures the quality of the insulation by introducing a high voltage/low current thru the conductor being tested.usually in my experience it is pass or fail.What i don't get though is how does the megger tell me that a wire is bad when one side of the wire is obviously open?
in the ranger12 post.
Bookmarks
