Results 1 to 3 of 3
Thread: Walk-In Freezer Receptical
  1. #1
    Join Date
    Jan 2004
    Posts
    29
    Does anyone know if it's a code violation for an in use 120v receptacle mounted near the evaporator in a walk-in freezer to exist? It's needed to keep the drain line heater functional. There is no weatherproof cover.
    Thanks
    Mike Reisen
    All Air & Electric
    Arlington, Texas
  2. #2
    Join Date
    Apr 2004
    Posts
    113
    Re: Walk-In Freezer Receptical
    should be ok as long as the conduit is sealed where it exits through the wall or ceiling of the cooler. As to weatherproof, many schools of thought on that one. I recommend compression connectors and weatherproof boxes, but have also seen standars boxes and set screw connectors pass inspection. The important thing is to seal the conduit.(duct seal, silicone, etc in the conduit)
  3. #3
    Join Date
    Feb 2003
    Portage, Indiana NEC: 2008
    Posts
    9,911
    I believe the cooler is a damp location and will require listed equipment for use in damp locations.
    This comes from article 100 definition of a damp location:
    Location, Damp. Locations protected from weather and not subject to saturation with water or other liquids but subject to moderate degrees of moisture. Examples of such locations include partially protected locations under canopies, marquees, roofed open porches, and like locations, and interior locations subject to moderate degrees of moisture, such as some basements, some barns, and some cold-storage warehouses.
    Wayne A. From: N.W.Indiana
    Be Fair, Be Safe
    Just don't be fairly safe
Posting Permissions
  • You may not post replies
  • You may not edit your posts
