I have a very small stand alone restroom where the hand dryer is causing the lights to dim and the emergency lights to turn on due to the voltage drop. The drop is caused by the hand dryer and only lasts a second but what is the fix?
Can I add a capacitor to the hand dryer? How would it wire in to the unit could I put it on the feed to the unit even with the heater and moter down stream? How would I find out the correct size cap? Would the cap be in series or paralell?
Is there a better way?
