Results 1 to 6 of 6
Thread: One hour fire rating for recessed light fixtures
  1. #1
    Join Date
    Jun 2003
    Posts
    5
    Does anyone know anything about one hour fire rating for recessed lighting fixtures? Who requires this rating? Which standard, regulation, or code specifies this one-hour fire rating?
    Manny
  2. #2
    Join Date
    May 2003
    Salt Lake City, Utah
    Posts
    5,319
    Re: One hour fire rating for recessed light fixtures
    The one hour floor-ceiling assembly would be required by the building code due to certain conditions. The way I typically see this resolved is to build a 5/8" type X gypsum board box around the fixture. I have heard that someone has or is making a listed, 1 hour can that you simply install in the ceiling. It has the box I spoke of earlier built around it.
    Ryan Jackson, Salt Lake City
    Inspector, Instructor
  3. #3
    Join Date
    Feb 2003
    Posts
    1,257
    Progress makes them. They're called FireBox. There is even one that has a 2 hour rating. FYI, they are not cheap! They list price around $170. But it beats building the 5/8 box.
    Todd
    Live Long and Prosper.
  4. #4
    Join Date
    Jun 2003
    Posts
    5
    Is there any standard or document that clearly specifies the requirements?
  5. #5
    Join Date
    Apr 2003
    Westchester County, New York
    Posts
    3,552
    Hello mlabis
    That is a building code issue. Not all installations of recessed cans are in a 1 hour fire rated ceiling, therefore not all cans need this kind of construction. Check with the building inspector to see if they are required in your particular case.
    Pierre
  6. #6
    Join Date
    Feb 2003
    Posts
    109
    Manny,
    Here is a excerpt from the 99 BOCA National Building Code.
    407.3 Beneath rooms:
    Private garages located beneath habitable rooms in occupancies in Use Group R-1, R-2, R-3 or I-1 shall be separated from adjacent interior spaces by fire partitions and floor/ceiling assemblies which are constructed with not less than a 1-hour fireresistance rating. Wood structural members of the minimum dimensions specified in Section 2304.0 for Type 4 construction shall be acceptable without any further protection where a 1-hour fireresistance rating is required.
    I hope this helps
    Greg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
