Closed Thread
Results 1 to 3 of 3
Thread: Table 430.150
  1. #1
    Join Date
    Dec 2005
    Posts
    1
    Table 430.150
    Does anyone know if there have been any changes to table 430.150 in the 2005 NEC? Specifically are the three phase motor aperage ratings still the same as the 2002 code book?
    Thanks,
    Jimmy
  2. #2
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    16,221
    Re: Table 430.150
    I think you mean Table 430.250. There is a Revision Bar in the left margin on the explanatory notes at the top of the table. But there is no similar Revision Bar in the table itself. I infer that the numbers are the same.
    Charles E. Beck, P.E., Seattle
    Comments based on 2008 NEC unless otherwise noted.
  3. #3
    Join Date
    Dec 2004
    Fort Collins, CO NEC: 2011
    Posts
    15,039
    Re: Table 430.150
    Jimmy, the name of the table changed from 430.150 to 430.250.
    -George
Closed Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
