Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Edison Circuit
  1. #1
    Join Date
    Nov 2004
    Posts
    284
    Edison Circuit
    What's the difference betwen an Edison Circuit and Mutlwire Branch circuit?
  2. #2
    Join Date
    Feb 2003
    Indianapolis
    Posts
    6,102
    Re: Edison Circuit
    Name, I believe they are the same (that is a guess on my part).
    Charlie Eldridge, Indianapolis, Utility Power Guy
    Responses based on the 2011 NEC, unless stated otherwise.
  3. #3
    Join Date
    Feb 2003
    Florida
    Posts
    7,637
    Re: Edison Circuit
    The system was originally designed by Edison himself for his Direct Current systems. In those days, conductor costs were the primary factor for electrical installations and this "new" system provided a means for supplying two circuits using only three wires. This made for significant savings.
    This concept was borrowed by Tesla and Westinghouse during the developement of the alternating current system. It later became known as the multiwire branch circuit.
    On a side note, I believe the 3 wye multiwire systems were once called the "round robin circuit".
    Bryan P. Holland, MCP
    NEMA - Codes & Standards
  4. #4
    Join Date
    Feb 2004
    Posts
    634
    Re: Edison Circuit
    how can you use a mutlwire branch circuit on DC?
  5. #5
    Join Date
    Nov 2004
    Posts
    284
    Re: Edison Circuit
    I was just asking because I did trim with a guy yesterday, and I was looking at the panel and there was some 3-conductor, and I asked him what it was going to, and he said it was a "edison circuit"...which when he explained it, seemed just like a Multiwire BC.
  6. #6
    Join Date
    Apr 2003
    Posts
    5,156
    Re: Edison Circuit
    I think it might be more productive to ask what the differences would be.
    Edit: I can't seem to stop misspelling
    [ December 21, 2004, 02:04 PM: Message edited by: physis ]
    Sam, San Francisco Bay Area
  7. #7
    Join Date
    Feb 2003
    Florida
    Posts
    7,637
    Re: Edison Circuit
    The system is identical to a 3-wire AC system except that the loads are connected between two positive leads of a DC generator which both share a common negative lead.
    I believe Edison used 2-100V generators for his typical system.
  8. #8
    Join Date
    Feb 2003
    Tennessee
    Posts
    1,651
    Re: Edison Circuit
    I never did see a DC circuit set up like the Edison AC system but I assumed the common would be a negative and a positive tied together? If you tied the positives or negatives together and used them as a common you wouldn't have the benefit of being able to balance it and have the same size common.
    Ronald
    [ December 21, 2004, 04:43 PM: Message edited by: ronaldrc ]
  9. #9
    Join Date
    Apr 2003
    Posts
    5,156
    Re: Edison Circuit
    I tried to find a link to something regarding DC Edison circuits but all I could find was a bunch of spooky stories of the dreaded AC version of the Edison circuit.
    From what's being said on the internet I think we should all start businesses that remove the dangerous and deadly multiwire circuits from innocent peoples homes.
  10. #10
    Join Date
    Nov 2004
    Posts
    284
    Re: Edison Circuit
    Yeah, the only few things I found were about how bad Multiwire Branch Circuits were when I did research.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
