Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: grounding conductor crimp fittings?
  1. #1
    I was wondering what exactly do you call those crimp connectors, that are always used on making an irreversible crimp connection on all the bare grounding conductors, are called. You know the copper crimp connector on like four egcs in one box. What are they actually called? Where can I find them, and how do I crimp them? :o
    Dan Thomas
    Industrial Electrician, Indiana
  2. #2
    Join Date
    Apr 2003
    Planet macmikeman
    Posts
    3,443
    Re: grounding conductor crimp fittings?
    Mr Thomas, If you go into a wholesale house and request for "stake-on" crimps you will probably get directed to the product you are looking for. Another way to enquire is to request for (sic)" Buchanen" barrels.
    85deg. an Sunny today.
  3. #3
    Join Date
    May 2003
    North Carolina
    Posts
    1,613
    Is this what you are referring to? Made by Ideal (and other manufacturers)
    It requires this
    tool to crimp.
    Available at any electrical supply house.
    John, Chair City, NC
    Technology: Mans best efforts to make things as good as they used to be
  4. #4
    Join Date
    Feb 2003
    Boston, MA
    Posts
    6,870
    I belive they are called a pain in the *** for the next guy that has to work in that box.
    There are two kinds of people - those smart enough to know they dont know, and those dumb enough to insist they do.-----Margery Eagan
    Open shop since 1988
  5. #5
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,767
    Well, I believe they're called 'ferrules', and can get one off in 5 to 10 seconds (without damaging the wires).
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  6. #6
    Join Date
    Feb 2003
    San Diego
    Posts
    568
    Larry,
    How do you get the ferrules off the wires without damaging them?
    ~Peter
  7. #7
    Join Date
    May 2003
    Posts
    1,249
    Cut down the length of the splice cap with a good pair of dykes, and hope the splice cap is copper and not steel.
  8. #8
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,767
    Originally posted by peter:
    Larry,
    ~Peter
    By simply squeezing the ferrule round with my Kleins. It then will twist off like a nut from a bolt, if it's too tight to slide off.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  9. #9
    Join Date
    Apr 2003
    Planet macmikeman
    Posts
    3,443
    Fellow posters, please forgive me for hijacking the post but I have a related question. I have run across many instances where these same barrel crimps have been used on current carrying conductor splices with just wraps of electrical tape to insulate them. I am pretty sure this is a code violations but am not sure. Anybody know?
  10. #10
    It requires this
    tool to crimp.
    Yes this is what I was looking for. I did not relies that they could be crimped with regular crimpier, which I already have. The look harder to crimp and I did not think my crispers would do the job. Thanks everyone, I felt stupid having to ask this, but been doing industrial wiring, and we do not use them. I am now getting into doing residential wiring on side. So I know need to know, and I would rather ask here then show my lack of knowledge out in field.
    Thanks again.
    Dan Thomas
Posting Permissions
  • You may not post replies
  • You may not edit your posts
