Results 1 to 3 of 3
Thread: Single Core AC Cable installation
  1. #1
    Join Date
    Nov 2005
    Posts
    18
    Hello All
    Another new question. I'm inspecting the construction of a land drilling rig with AC drives.
    I do know that on marine installations the requirement is that single core AC cables must be run in TRIADS for distances of 30 meters or greater and all pentrations must be through a non-ferrus material with non ferris glands.
    I have not been able to find a simular requirement in the NEC.
    Thanks
    ettek
  2. #2
    Join Date
    Feb 2003
    Illinois
    Posts
    23,321
    Re: Single Core AC Cable installation
    That is a design issue, not a code issue.
    Don
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
  3. #3
    Join Date
    Nov 2004
    Posts
    1,525
    ettek -
    Take a look at 300.20. It reads about the same, except there is no length requirement. All the conductors have to run together.
    Although, I can't tell you if "land drilling rigs" fall under the NEC
    carl
    Using the code for a design guide is a sign of incompetance
Posting Permissions
  • You may not post replies
  • You may not edit your posts
