Results 1 to 10 of 10
Thread: Distance between gas and electric
  1. #1
    Join Date
    Jun 2005
    Posts
    2
    Is there a code that states that there must be a minimum distance of 36 inches between a gas meter and a meter/main or distribution panel? Thanks for anything you can contribute.
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,158
    Re: Distance between gas and electric
    I don't recall an NEC requirement but here in NJ one of our local POCO's requires the 36" that you've mentioned.
    Rob
  3. #3
    Join Date
    Jan 2005
    Posts
    3,034
    Here it is 36 in from source of possible ignition.But that only pertains to meter vent.I have seen meters encroach that distance and the gas company extended their vent in pipe and it passed.If there is a meter distance in affect then why wouldn`t their be the same restrictions on drops off gas service :confused: IE: dryer,stove,wh,oven ...........
  4. #4
    Join Date
    Jun 2005
    Posts
    2
    Thanks Infinity, I'm also from NJ originally, but in California now and that's where I'm being held to this "code issue?" The inspector will not pass me until I rectify it.
  5. #5
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,747
    California has its own version of the electrical code. Each time the NEC is published, they mark it up, deleting, revising, or adding text, to suit their preferences. Other jurisdictions do the same (I know Seattle is one of them). Do you have a copy of the California Electrical Code? If not, you probably should buy one. It may or may not have the answer to your specific question. But as I understand things, the NEC does not apply in California. It has been superseded in its entirety by the California Electrical Code.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  6. #6
    Join Date
    Feb 2005
    East Tennessee
    Posts
    74
    National Fuel Gas Code 2.7.2(c) Gas meters shall be located at least 3 ft(0.9 m) from sources of ignition.
  7. #7
    Join Date
    Feb 2004
    federal way,washington
    Posts
    1,240
    Is a meter considered a source of ignition? I dont think so IMHO
  8. #8
    Join Date
    Dec 2003
    TAMPA FLORIDA
    Posts
    4,576
    The problem is the regulator is at the meter.And it does release gas
    Tampa Florida
  9. #9
    Join Date
    Dec 2004
    Windsor, CO NEC: 2017
    Posts
    16,108
    Stew, it's a gas company thing, that's about as much as I know. They think PVC and meters could spark, so we have to avoid them.
    See this thread.
  10. #10
    Join Date
    Feb 2003
    New York
    Posts
    298
    In my area of NY, The Poco requires at least one foot between gas meter & electric meter.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
