Results 1 to 9 of 9
Thread: Temporary Power Taps-Surge Protectors
  1. #1
    Join Date
    Mar 2003
    Minnesota
    Posts
    392
    The power strips that are used for surge protection are labeled Temporary Power Taps. Can they be used in a permanent application or are they considered a temporary wiring and after 90 days would have to be removed? I could not find anything in NEC on this. Are they extension cords?
  2. #2
    Join Date
    Feb 2003
    Florida
    Posts
    7,637
    Re: Temporary Power Taps-Surge Protectors
    Per UL, they are not an extension cord. They call these relocatable power taps. They cannot be permanently installed by securing them to the structure or building surface, however they can be used permantently if just laying on the floor or surface of the work area.
    XBYS.GuideInfo
    Bryan P. Holland, MCP
    NEMA - Codes & Standards
  3. #3
    Join Date
    Mar 2003
    Minnesota
    Posts
    392
    And where is this in NEC? or is this UL?
    [ November 02, 2005, 10:04 AM: Message edited by: muskiedog ]
  4. #4
    Join Date
    Feb 2003
    Florida
    Posts
    7,637
    This is per UL, click on the link in my first post. The NEC does not have much to say about these devices.
  5. #5
    Join Date
    Mar 2003
    Minnesota
    Posts
    392
    Thanks. I now know more than I want to know.
  6. #6
    Join Date
    Mar 2003
    Minnesota
    Posts
    392
    Okay, now is there a limit on how many can be connected to the wall outlet? one or two. I would assume that two would be fine as long as we are not applying more amps then it was designed to handle.
  7. #7
    Join Date
    Aug 2004
    Northern illinois
    Posts
    16,515
    I think it is ironic that it is not considered acceptable to install them in a permanent manner yet many of them come with mounting ears for just that purpose.
    Bob
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,929
    I agree Bob. It's also ironic that you can not plug one into another. Looking under my desk right now I see over 30 things plugged in to various receptacles and power strips. And they're all on the same circuit.
    Rob
  9. #9
    Join Date
    Feb 2003
    Wisconsin
    Posts
    9,853
    Bob,
    All of the strips I have seen have "keyhole" type mounting provisions which allows them to be removed without tools. Since no tools are required I do not consider them as permanently mounted.
    Just because you can, doesn't mean you should.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
