threephase
What have others found successful when needing to install a small nipple between two panelboards when one is flush mounted in drywall and you plan on mounting an additional subpanel/transfer switch surface mounted?
Pics would be great if possible.
If you offer to install the new panel flush to match the existing, what additional charge do you normally charge?
Thanks so much.
Threephase
Thanks so much.
Threephase
