Go Back   Mike Holt's Forum > NEC
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Closed Thread
Thread Tools Search this Thread Display Modes
  #1
Old 07-15-2003, 09:38 AM
maverick the electrician maverick the electrician is offline
Junior Member
Default ADA switch heights code?
We are having a debate on the ADA switch height code? Please give us a hand. thanks
  #2
Old 07-15-2003, 09:56 AM
ryan_618's Avatar
ryan_618 ryan_618 is offline
Default Re: ADA switch heights code?
The ANSI A117.1 states that reach is 15"-48". IMO, 48" to the center is the highest permitted.
__________________
Ryan Jackson, Salt Lake City
Inspector, Instructor
  #3
Old 07-15-2003, 10:04 AM
Junior Member
Trying to figure it out. We we're told it was 42 to center?
  #4
Old 07-15-2003, 10:07 AM
ryan_618's Avatar
42" is fine, but its not the highest you can install.
__________________
  #5
Old 07-15-2003, 10:57 AM
roger's Avatar
roger roger is offline
These may help.
Figure 5b
Maximum Forward Reach over an Obstruction
The maximum level forward reach over an obstruction with knee space below is 25 inches (635 mm). When the obstruction is less than 20 inches (510 mm) deep, the maximum high forward reach is 48 inches (1220 mm). When the obstruction projects 20 to 25 inches (510 mm to 635 mm), the maximum high forward reach is 44 inches (1120 mm). (4.2.5, 4.25.3).
Figure 6(b)
High and Low - Side Reach Limits
The 30 by 48 inch wheelchair clear floor space is located a maximum 10 inches (255 mm) from the wall.
Figure 6(c)
Maximum Side Reach over Obstruction
If the depth of the obstruction is 24 inches (610 mm) and the maximum height of the obstruction is 34 inches (865 mm), the maximum high side reach over the obstruction is 46 inches (1170).
Roger
__________________
Closed Thread
CEU Banner Forum Pages
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
