Results 1 to 2 of 2
Thread: Water cooler receptacle
  1. #1
    Join Date
    Jul 2003
    Miami, Fl
    Posts
    3
    do electric water cooler outlets need to be gfi? and are outlets within 6 ft. of electric water coolers also need to be gfi??
    please where is it in NEC??
  2. #2
    Join Date
    Feb 2003
    Illinois
    Posts
    23,468
    Re: Water cooler receptacle
    It is not in the code...the NEC does not require GFCI protection for that application.
    Don
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
