Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: outlet receptacle distance from WALL?
  1. #1
    Join Date
    Jun 2005
    Posts
    4
    Is there a maximum distance an outlet box must be placed away from a wall? I'm not talking height here, but distance from a wall (horizontally).
    Aesthetics aside, I'm curious about the code.
    -Rudy
  2. #2
    Join Date
    Apr 2003
    Westchester County, New York
    Posts
    3,552
    Re: outlet receptacle distance from WALL?
    A floor receptacle can be in any location in the floor. If the floor receptacle is being installed to meet the wall measurement for 210.52, then the floor receptacle can be no more than 18 inches from the wall.
  3. #3
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,482
    Don't know that I'm following you. The minimum distance around walls for general purpose residential receptacles generally starts at 6 feet from a door then every twelve feet around the room. This is based on the fact that all lamps and other devices such as TV's have 6 foot cords so with a 12 foot spacing everything should reach without extension cords.
    -Hal
  4. #4
    Join Date
    Mar 2004
    Arizona
    Posts
    3,913
    bega,
    you can start from the first stud on the wall or up to 6' from there.
    frank
    Frank Arizona,USA
  5. #5
    Join Date
    Dec 2003
    TAMPA FLORIDA
    Posts
    4,576
    Anyone notice this is his first post and he listed computers as line of work.
    Tampa Florida
  6. #6
    Join Date
    Jun 2005
    Posts
    4
    Sorry I'm not more clear. I want a wall outlet right near the corner of a room...when all is said and done, the BOX would be 1.5 inches away from a FINISHED wall. I have my reasons for this, but my electrician is telling me "that's against the National Code". He couldn't give me a "number of inches away it has to be, so...it sounded suspicious to me...so I'm digging around.
    Everything else is good...I have plenty of outlets so the 12' rule is no problem.
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,759
    It could be right against the finished wall as long as you could get the plate on.
    Rob
  8. #8
    Join Date
    Feb 2005
    NJ
    Posts
    9,328
    [quote]Originally posted by bega:
    D...it sounded suspicious to me...so I'm digging around.
    This sounds suspiciously like a DIY question.
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    CELTIC
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    An error on your part does not constitute an emergency on my part.8-)
  9. #9
    Join Date
    Jun 2005
    Posts
    4
    Thanks for the answer.
    Well, if I can't convince my guy to do this for me, it may turn into that. I build webpages for a living. I know a little bit about electricity. I'm sure I could do this myself, but I've seen enough DIY websites to know that I'm no electrician. I hope that makes sense.
  10. #10
    Join Date
    Dec 2003
    TAMPA FLORIDA
    Posts
    4,576
    I am having a problem in believing any electrician would tell you this is a violation,for the record it is not a violation.Rather unusual and perhaps he has some reason your not stating as to why he wont do this.Simply hire another electrician and do what your qualified for.
    Tampa Florida
Posting Permissions
  • You may not post replies
  • You may not edit your posts
