Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: breaker off but lights are still on
  1. #1
    Join Date
    Apr 2003
    Missouri
    Posts
    11
    i have a customer who said his breaker tripped but his lights are still on. he moved the wire to a different breaker and it did the same thing. he said when he pulled the wire from the breaker the lights did go out. could the neutral bar be hot?
  2. #2
    Join Date
    Mar 2003
    New England
    Posts
    13,225
    Re: breaker off but lights are still on
    Huh? :confused: :confused:
  3. #3
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,876
    Perhaps the customer did not explain the circumstances very clearly to you, but your explanation is certainly not clear. I would ask a number of questions of this customer:
    </font>
    • <font size="2" face="Verdana, Helvetica, sans-serif">How did this situation first make itself known to you? What I mean is, if the lights did not go out, how did you become aware that a breaker had tripped?</font>
    <font size="2" face="Verdana, Helvetica, sans-serif"></font>
    • <font size="2" face="Verdana, Helvetica, sans-serif">Was there any work done recently on the home wiring? This includes new breakers, new circuits, moving circuits to different breakers, adding lights or receptacles, or replacing anything.</font>
    • <font size="2" face="Verdana, Helvetica, sans-serif">When you say that you moved this circuit to another breaker, how did you dot that? Was there a spare breaker, or did you swap the wires on two breakers?</font>
    • <font size="2" face="Verdana, Helvetica, sans-serif">I presume (or I hope) that as you moved the wire to a different breaker, the breaker was turned off. Then, when you turned the breaker on, did it trip right away?</font>
    • <font size="2" face="Verdana, Helvetica, sans-serif">Were the lights off when the wire was disconnected, and did they come back on when you snapped the breaker back in (i.e., before you even turned on the breaker)?</font>
    <font size="2" face="Verdana, Helvetica, sans-serif">That is just off the top of my head. I'd have a bunch of other questions.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  4. #4
    Join Date
    Dec 2003
    TAMPA FLORIDA
    Posts
    4,576
    I will need 6 more beers before i even try to figure this one out,back in 30 minutes
    Tampa Florida
  5. #5
    Join Date
    Feb 2003
    Fl
    Posts
    17,023
    Wait a minute, this is 8/15/05 not 4/01/05.
    I agree with Jim on the beers, but I think the customer may have already had 6 or 24.
    Roger
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,876
    I think the customer is a "DIY." You know, "Destroy It Yourself."
    Tell you what: I'll buy youse guys a couple beers, and youse guys buy me a couple "Makers Mark on the Rocks," and we'll be ready to solve all of this customer's problems.
  7. #7
    Join Date
    Dec 2003
    TAMPA FLORIDA
    Posts
    4,576
    Only way it could happen the way he told it is to have a shorted breaker.If removing the wire from an off breaker kills the light the breaker is shorted.Tell customer to put the bottle down and try again in the morning,hick!
    Tampa Florida
  8. #8
    Join Date
    Feb 2003
    Fl
    Posts
    17,023
    Charlie, [quote]Originally posted by charlie b:
    [b] I think the customer is a "DIY." You know, "Destroy It Yourself."
    Roger
    Join Date
    Dec 2004
    Windsor, CO NEC: 2017
    Posts
    16,183
    Could the breaker have...er...broken in the "closed" position?
    Or is the light on a different circuit?
    I need beer.
  10. #10
    I think your customers lights are on, but no one is home. Gee, I wonder what will happen if I do this? If all else fails, call an electrician. If you are the electrician, proceed with caution an amateur may have set a trap for you.
    Where ever you go... there you are
Posting Permissions
  • You may not post replies
  • You may not edit your posts
