Results 1 to 5 of 5
Thread: Panel buzzing
  1. #1
    Panel buzzing
    Aside from an obvious culpret like a bad breaker, what could be the cause of a "buzzing" noise coming from a breaker (main load) panel????
  2. #2
    Join Date
    Aug 2004
    Plainfield, IN
    Posts
    908
    Re: Panel buzzing
    Could be the load of the circuit approaching the rating of the breaker.
  3. #3
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,968
    Re: Panel buzzing
    Could be a good breaker that is badly mounted (i.e., loose bolts).
    Could be someone inside trying to get someone to open the door to let them out.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  4. #4
    Join Date
    May 2003
    Salt Lake City, Utah
    Posts
    5,319
    Re: Panel buzzing
    You can't put a doorbell transformer or switch in the panel. Tell the people in the panel to knock loudly, not ring the bell. :mad:
    Ryan Jackson, Salt Lake City
    Inspector, Instructor
  5. #5
    Join Date
    Jan 2004
    Posts
    233
    Re: Panel buzzing
    Does this feed nonlinear load which could change freq. which may be the noise you are hearing
Posting Permissions
  • You may not post replies
  • You may not edit your posts
