Results 1 to 8 of 8
Thread: South Carolina Journeyman Exam...
  1. #1
    Join Date
    Mar 2006
    Seneca, SC
    Posts
    2
    Where can I find the most info on SC Journeyman exam preparation? I would appreciate any direction to some good literature to help me refresh on key points for the current exam.
    Im a practicing electrician for 15 years, and on site supervisor for close to 8, without my journeyman card. I took a correspondence corse about 7, years ago and like a Idiot i did not go straight and take my test while most of the literature was fresh on my mind etc. I sure as hell do not use most of the material i recall studying/learning there-in on a daily basis. It would be a disaster if i walked in and took that bad boy right now.
    Some of the GC's in my area, as well as inspectors offices in surrounding areas are requiring someone in my position to have the journeyman liscencse. So needless to say its time to get off my butt and finish what I started & I would greatly appreciate any help.
  2. #2
    Join Date
    Mar 2006
    close to greenville sc
    Posts
    1,020
    sc exam
    I have took the exam several times, the references they use to create the exam are:
    Alternating Current Fundamentals, sixth edition WWW.delmarlearning.com Mike Holts Illustrated Guide to Basic Electrical Theory second edition WWW.necode.com
    Printreading Based on the 2005 NEC WWW.go2atp.com
    And they list a toll free Number to obtain exam references 877-624-2562
    The best thing to do is get very familiar with looking things up in the code book because the questions aren't what most people would use on a regular basis. Good Luck it is a very tough test.
  3. #3
    Join Date
    May 2004
    Indianapolis, IN
    Posts
    702
    In case you didn't already know, SC is on the 2002 Code still.
    I see that the test is given by PSI. The last PSI test I took was computer based. Don't know if this one is or not.
    Good luck
    Brad Darnell
    Master Electrician -Electrical Contractor
    IN-NJ-WI-CT-LA-OH-KY-TX-FL-NV-GA-TN-MS-OK-IL-NC-AL-KS
    "The Code doesn't say what you think it says" - Charles E. Beck, P.E.
  4. #4
    Join Date
    Mar 2006
    Posts
    1,020
    test
    SC is still on the 2002 code but, The test is based on 2005. It states on the application sheet to bring 2005 "or you will get the wrong answer's". It is open book 80 multiple choice questions with a 3 hour limit. And not on a computer. Thomson Prometric gives the test, their web site is http://www.experioronline.com/
  5. #5
    Join Date
    May 2004
    Indianapolis, IN
    Posts
    702
    Boy, did I have some bad info. Thanks for the corrections. :oops:
    Brad Darnell
  6. #6
    Join Date
    Mar 2006
    Posts
    1,020
    thats cool
    That's Cool, at least you are trying to help. I only know because I have the application form in my hand!
  7. #7
    Join Date
    Mar 2006
    Posts
    1,020
    test
    PS dunriteman
    PM me and i can send some attachments that some folks have sent me. (really helpful people, hope i pass!)
    And since you are in the upstate of SC then i assume you will be testing in greenville (whatley center)? Well, if you use reading glasses bring several pairs, it's not a very good environment for a test. it is a very old, run down building, with a busy street by the window, a playground, and sparse lighting (thats why i say bring several pairs! or maybe your own light?). it is very hard to keep your attention on what you are doing. You will be taking the test with other people that are taking the "other" test's like plumbing and gas. thats not such a big deal unless like the last time i had someone taking a different test behind me and he could either not see or read and he had an assistant reading the question and multi choice questions to him......
  8. #8
    Join Date
    Mar 2006
    Posts
    1,020
    Just found this
    I just found this practice for the Experior exam (which is now Prometric). I checked the sample page and it has the same questions that are on the SC exam. I believe this may be a big help! http://www.electricianeducation.com/exams/jeexp.htm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
