480sparky said:Every tamper switch I've seen was made by these guys:
http://www.pottersignal.com/sprinkler/listproducts.php?type=supervisoryswitches
Usually the fire suppresion sub supplies and installs them. I just hook 'em up the the FACP.
lakevillejake said:if you are refering to panel tamper switch which goes into panel box to signal opening of panel cover. they can be found at adi national retailer of alarm parts and equipment.
gadfly56 said:Actually, I think what he needs is an SD500-AIM, which is an input module to turn a "dumb" switch into an addressable point. You would get these from Silent Knight or a distributor local to you.
