Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: In-use covers
  1. #1
    Join Date
    Jun 2006
    Posts
    1
    In-use covers
    Let's not get into local issues, just the NEC. On a new single family dwelling, are in-use covers required on all exterior receptacles? If so Code article numbers would be great. Thanks have a great day.
  2. #2
    Join Date
    Dec 2004
    North Carolina
    Posts
    4,484
    Read 406.8
    Mike Whitt
    God answers Knee-Mail.
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,138
    Quote Originally Posted by dad
    They are only required on a receptacle in wet locations. A hinged type cover can be used in damp locations.
    Rob
  4. #4
    Join Date
    Dec 2004
    Windsor, CO NEC: 2017
    Posts
    16,199
    Due to varied interpretations of "protected from the weather", I have taken to installing in-use covers in all locations outside. Just my preference.
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,138
    Quote Originally Posted by georgestolz
    Would your customers be happy with a big bubble cover hanging on the underside of their outdoor soffits? Mine would scream if they had to look at those ugly covers hanging there.
    Rob
  6. #6
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,826
    We typically use a 45-degree angle for wind-blown rain in determining the wet/damp issue. In other words, if the receptacle is 7' below the roof edge, it needs to be at least 7' under the protecting roof/eave, etc. to avoid the bubble.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  7. #7
    Join Date
    Feb 2003
    New Jersey
    Posts
    3,610
    Quote Originally Posted by infinity
    And herein lies the problem !!! Your AHJ and the NEC may require you to install those bubble covers but I can guarantee you that those will quickly change to the flip cover after the inspection process (either by an electrician or by the homeowner). Manufacturers (like Intermatic) are touting slogans on their products that indicate "It's the Code" but I'd be willing to bet that none of them live in a mega-mansion that took a $million or so to build.
    My opinion, either re-write the code to include only those receptacles that have a definite use and have a cord plugged in at all times or compel the manufacturers to come up with a product that isn't so obtrusive and that can be easily attached to an outdoor receptacle by a homeowner.
    Just my opinion. Not looking to become part of the CMP !!!
  8. #8
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Phil I doubt this is what you meant but it sounds like your saying there should be a separate set of rules for folks who have mega-mansions that took a $million or so to build.
    How about this, they pay a little more for the carpenters to build a cubby hole in the wall to hide the outlet or have the electrician use a recessed box like the one Arlington sells?
    http://www.aifittings.com/whnew74.htm
  9. #9
    Join Date
    Dec 2004
    Posts
    16,199
    No, that is an exception. I use damp covers for the soffits.
  10. #10
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,138
    We do also. I was saying that in response to the OP question that all exterior receptacles do not require so called in-use covers.
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
