I have a circuit where i need to install a UPS. It will be feed by a system with Tansfer automatic switch, it is mean the neutral will be break during transfer . I know that the best solution to avoid the break of the neutral is to install a isolation transformer for the UPS but what is the problem if just i connect the neutral to earth after the main circuit breaker that feed the UPS.
