Results 1 to 3 of 3
Thread: A good way to explain Class I Div 1 & 2
  1. #1
    Join Date
    Feb 2004
    Posts
    267
    During a recent discussion of Class I Division 1 requirements, I explained it this way:
    Class I Division 1 means I can pour gasoline on the machine and it will keep running without igniting it.
    Class I Division 2 means that I can pour gasoline on the machine and I can shut it down before it ignites, and when it is off it won't ignite the gasoline.
    I know I omitted the group here but that complicates the explanation. Anyone who's ever tried to re-start a charcoal grill after re-lighter fluiding it or used gas to start burning leaves or scrap, knows from their unsuccessful (or maybe successful) attempt at winning a Darwin award, how easy it is to start the fire/explosion.
    If anyone has better analogies, feel free. When you specify equipment for a classified location, the accountants become apoplectic and need a good answer where they walk away understanding, not thinking that maybe they're being techno-bs'd.
    Matt
  2. #2
    Join Date
    Aug 2004
    Posts
    10
    I'm not sure why you would need an analogy....
    Class I Division I:
    Where ignitable concentrations of flammable gases, vapors or liquids can exist all of the time or some of the time under normal operating conditions.
    Class I Division II :
    Where ignitable concentrations of flammable gases, vapors or liquids are not likely to exist under normal operating conditions.
  3. #3
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,105
    Part of the problem with your analogy is that you probably wouldn’t shut down the process in a Division 2 location either.
    "Bob"
    Robert B. Alexander, P.E.
    Answers based on 2014 NEC unless otherwise noted.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
