Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Wire nuts for #6 wire?
  1. #1
    Join Date
    Nov 2004
    Naples,FL 34110-9285
    Posts
    300
    Is there such a thing as a wire nut rated for spliceing #6 wire?
    IMO nobody is perfect
  2. #2
    Join Date
    Feb 2006
    Pa.
    Posts
    2,021
    Ideal 454 Blue lists 2 #6 with 1 # 12.
    Rick
  3. #3
    Join Date
    Nov 2004
    Posts
    300
    the box I have looked at says wire range is #14-#8 for blue wire nuts
    just started thinking that I have never seen a wire nut rated for #6 wire.have always used split bolts and just started to wonder why.
    going to go do a search of Ideal wire nuts
  4. #4
    Join Date
    Feb 2003
    Snohomish, WA
    Posts
    1,442
    Quote Originally Posted by marinesgt0411
    Their website says 2-#6 with 1-#12.
    Or goto http://www.idealindustries.com/pdf/Combinations.pdf for the skinny on all their wirenuts.
    It's not rocket surgery!
  5. #5
    Join Date
    Feb 2003
    New Jersey
    Posts
    3,577
    Polaris and NSI make insulated bugs. Irrespective of what thw wire nut mfr's say, when it comes to amperage ratings I'd rather use these bugs than a wire nut. If I can find a link I'll post it here.
  6. #6
    Join Date
    Apr 2005
    Reno
    Posts
    621
    For #6 & bigger I always use split bolt connectors. I think they work great.
  7. #7
    Join Date
    Mar 2006
    Peoria, Illinois
    Posts
    112
    I've also liked lugs bolted together for some of the motors that had #6 or larger supplying them. Usually had a couple of motor leads for each supply line. Followed up w/ mylar (sp?), 3M 125C "streach" tape, and 2 layers of Super 33+. That always lasted longer than the motor.
    . . .come to think of it, if it was just #6, I didn't use the mylar; just a layer of 33+ upside down. The mylar would have taken up too much space.
    Edit once for spelling!
    Sometimes I'm only as good as my Plan B. ;)
  8. #8
    Join Date
    Apr 2004
    Minneapolis, Minnesota
    Posts
    1,710
    I have some Ideal blues I recently used to splice some #6. Not a fun task. Next time I'm going to use split bolts or butt splicers.
    Jeff
    EIT (full-time)
    EC (part-time)
  9. #9
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    I doubt I will ever by split bolts I just never liked them.
    There are just so many other choices many of which are pre-insulated and easily removable / reusable that IMO split bolts are history.
    But as far as the OP I would use the Idea 454s that where already mentioned.
  10. #10
    Join Date
    Feb 2003
    Snohomish, WA
    Posts
    1,442
    Quote Originally Posted by iwire
    I agree with the Polaris type connectors out now. A bit more money, but well worth the savings in labor. Great for motor connections. If the rotation is backwards. No problem.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
