Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: For recessed lighting - what does the IC mean?
  1. #1
    Join Date
    Jan 2006
    Southern NH
    Posts
    881
    I haven't installed recessed lighting in over 10 years. and in looking trough the Halo Lighting site, I noticed housings - some were I see IC and Non-IC versions.
    I know that you need clearance between insulation, but when they list a clearance, does that distance also specify distance from floor joists, etc.? I have a job I'm looking at with some recessed lighting that is for a drop ceiling in a basement.
    Thanks,
    Brett
  2. #2
    Join Date
    Oct 2006
    Baltimore, MD
    Posts
    3,161
    "IC" means the fixture is rated for direct contact with insulation, a non-IC needs a certain clearance, usually 3'
    John from Baltimore "One Day at a Time"
  3. #3
    Join Date
    Mar 2006
    Tampa Florida
    Posts
    8,009
    The I C cans have a thermal protector that opens circuit if can gets too hot.Although not always needed i suggest using them.Besure it actually say i c rated as some look as they do but are not rated.
  4. #4
    Join Date
    Jan 2006
    Southern NH
    Posts
    881
    So what does "IC" actally stand for?
    Quess: insulated can - but I doubt it
  5. #5
    Join Date
    Oct 2006
    Baltimore, MD
    Posts
    3,161
    Red face
    "Insulation Contact"? To be honest, I don't know either.
  6. #6
    Join Date
    Jan 2006
    Southern NH
    Posts
    881
    Well - I'm relieved - I thought it was only me. I actually felt a little dumb asking that question - but how else ya going to learn.
    That's why this site is so great - someone's always willing to jump in and give an answer.
    Thanks,
    Brett
  7. #7
    Join Date
    Oct 2006
    Baltimore, MD
    Posts
    3,161
    This forum is a fantastic learning tool-and it makes me keep my NEC within reach all the time!
  8. #8
    Join Date
    Jul 2006
    So Cal
    Posts
    58
    I was told "IC" meant "In Contact" and it could be in contact with the insullation... My source is a guy at the Home Depot, so take it for what it's worth...
  9. #9
    Join Date
    Sep 2006
    Posts
    159
    Because of supply and demand the IC cans are usually cheaper than the Non IC
    In residential work the only place I will use a Non IC can is for heat lamps in a bathroom
  10. #10
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,762
    According to Lightolier, the IC rating means "insulated ceiling" rated. The fixture can be completely embedded or covered with insulation.
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
