rated power input
albert rangel
New member
In a 3 phase 208 air conditioning unit, I hace 37kw cooling,21kw heating and on the name plate there is 17,600 watts rated power input. Which do i use fro breaker and wire size? Why is power input lower than heating and cooloing KW?
bob
Alabama
Would you use the heating and A/C at the same time?
The op says
Pierre
Why would it matter? Neither the 37kw cooling or 21 kw heat relate to the 17.6 kw input listed.
Albert
There should be a nameplate on the equipment with the max OC device and the minimum ampacity of the conductors.
