Don't over look the fact that there may be controls or other equipment that require a grounded conductor and therefore need the proper 220V. I'm not sure how the piece of equipment in question works, but You better make sure that the schematic agrees with putting a 110Vac on each leg, instead of 220V to ground.
In general, I think your asking for trouble. I would first determine why your having trouble and see if you can rectify the real problem, instead of putting on a band-aid.
"Just because you're paranoid, doesn't mean they're not out to get you"
Bookmarks
