Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Wire Type inside Pole Barn
  1. #1
    Join Date
    Oct 2006
    Posts
    23
    What is the correct type of wire to put "inside" an enclosed pole barn for lighting and plugs? Does code require UF cable or can I use regular NMB 12-2? Does it have to be in conduit?
  2. #2
    Join Date
    Jun 2005
    Logan, Utah
    Posts
    8,200
    That depends if the pole barn is classified as a Agricultural Building in accordance with Article 547.
    Take a look at 547.5 for the allowable wiring methods for an agricultural building.
    Chris
  3. #3
    Join Date
    Dec 2004
    North Carolina
    Posts
    4,483
    Quote Originally Posted by th111447
    What is the correct type of wire?
    I gotta say this, I can’t help myself, I just gotta say this one time.
    Use electric wires…hee, hee, hee, hee, hee, hee,
    Mike Whitt
    God answers Knee-Mail.
  4. #4
    Join Date
    Oct 2006
    Posts
    296
    If building is just classified as an accessory building by the building depart which is the case most of the time NM or UF cable can be installed but both will require protection unless routed in 2X4 or 2X6 stud walls
  5. #5
    Join Date
    Oct 2006
    Posts
    23
    The building is not being used for agriculture use. It is a residential pole barn.
  6. #6
    Join Date
    Aug 2004
    New Hampshire
    Posts
    209
    Quote Originally Posted by jwelectric
    Now that's damn funny.....
    Quote Originally Posted by Bea
    Not to sure that you could use either. Since the OP stated that it was a pole barn (it can not be attached to a dwelling unit unless that dwelling unit had the same type of foundation: poles. I doubt it. Since this is more then likely is a detached structure and one that probably doesn't meet the definition of a dwelling unit......I would have to say no to UF and no to NM...
    I would also go out on a limb to say the the OP just simply wanted to know the location type of a pole barn, wet, damp, or dry........But this is still my answer.
    Jim
    New Hampshire
  7. #7
    Join Date
    Jul 2004
    Louisville, Kentucky
    Posts
    2,141
    Quote Originally Posted by volt102
    Jim
    New Hampshire
    Why would you not use UF. I just put a service on a pole type structure and the Inspector insisted on UF with dust proof fittings.
    What would you use to wire this?
    Norb
    My Boss is a Tyrant and my Employee is an Idiot.
  8. #8
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,809
    You could use NM-C wire. But I don't know if its available.....
    Moderator-Washington State
    Ancora Imparo
  9. #9
    Join Date
    Aug 2004
    New Hampshire
    Posts
    209
    Quote Originally Posted by 1793
    A pole barn with a place to install the cables concealed behind a 15-minute finish rating?
    Now don't get me wrong, there may be such a thing, but up here in NH, I haven't seen one yet.
    Jim
    New Hampshire
  10. #10
    Join Date
    Jul 2004
    Posts
    2,141
    Jim
    New Hampshire
    Please don't get me wrong I'm not a confrontational kind of guy but why would this pole barn be any different than an unfinished garage or basement wired in NM?
    I'm here to learn
    Norb
Posting Permissions
  • You may not post replies
  • You may not edit your posts
