Results 1 to 5 of 5
Thread: Restrictions on flexible cords
  1. #1
    Join Date
    Dec 2004
    Posts
    8
    Under Article 400.8 Uses Not Permitted (3) When run through doorways, windows or similar openings; how strict are we talking? I've been requested to power up a piece of equipment on the other side of a doorway. There is no power in the area where the equipment is to be used. The equipment is temporary in its use, about (1) week, then it leaves my site for good. Can a cord be run through the doorway, if secured open to protect the cord?
  2. #2
    Join Date
    Jun 2006
    NJ
    Posts
    134
    croecken
    I'm not sure but does that not come under UL1640
    here is a link http://ulstandardsinfonet.ul.com/sco...p?fn=1640.html
    (e) section speaking about temporary constuction sites?
    I do entertainment work and everything we lay is temporary. extension cords, feeder ect. I think, in this instance, you are working in the same vein.
  3. #3
    Join Date
    Feb 2005
    NJ
    Posts
    9,328
    Have you checked 590?
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    CELTIC
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    An error on your part does not constitute an emergency on my part.8-)
  4. #4
    Join Date
    Dec 2004
    Posts
    8
    Edamico11- Doesn't apply in my situation, but thank you.
    Celtic-Thanks for pointing the way. 590.3(C) is what I needed.
  5. #5
    Join Date
    Feb 2005
    NJ
    Posts
    9,328
    Quote Originally Posted by croecken
    I was aiming at 590.4(H)
    Give it an eyeball
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    CELTIC
    ĦĦĦĦĦĦĦĦĦĦĦĦ
Posting Permissions
  • You may not post replies
  • You may not edit your posts
