Results 1 to 9 of 9
Thread: Bryant panels?
  1. #1
    Join Date
    Feb 2006
    Waterbury, CT
    Posts
    22
    Bryant panels?
    I have an old bryant panel that I am putting a new 15amp breaker into. Trying to find bryant breakers, I was informed cutler-hammer bought out bryant. I was also told cutler hammer breakers would fit a bryant panel. I put a CH breaker in and it would not hold, and no voltage could be read. Any suggestions?
    "It's better to burn out than fade away."
  2. #2
    Join Date
    Jun 2005
    Currently Carpentersville, IL
    Posts
    277
    Quote Originally Posted by Lithium1994
    I thought they were bought by Murray but it wouldn't matter unless they kept manufacturing the same ones... breakers must be approved for use in the panel. You can check this chart to see which panels the CH is approved for: http://www.eatonelectrical.com/unsec...A00304001E.PDF
    Half the guys here probably have used ones from panel upgrades. I'll check the bins later.
    (yes it's REALLY my name) HVAC/ Electrical Contractor licensed Chicago,IL ... I said its OFF! Don't you trust me?
  3. #3
    Join Date
    May 2003
    North Carolina
    Posts
    1,621
    John, Chair City, NC
    Technology: Mans best efforts to make things as good as they used to be
  4. #4
    Join Date
    Feb 2005
    NJ
    Posts
    9,328
    hmmm...what does "not hold" mean?
    Phyisically in the panel or stay closed?
    The breaker should be a "CH-BR" model...is that what you have?
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    CELTIC
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    An error on your part does not constitute an emergency on my part.8-)
  5. #5
    Join Date
    Jan 2004
    Right here.
    Posts
    12,326
    The Cutler Hammer "BR" series is BRyant. CutlerHammer took over the Bryant line.
  6. #6
    Join Date
    Feb 2003
    Wisconsin
    Posts
    4,350
    Refer to this copy of a letter from UL which should answer your questions directly.
    http://www.eatonelectrical.com/unsec...T01221002E.PDF
  7. #7
    Join Date
    Feb 2006
    Waterbury, CT
    Posts
    22
    thanks for all the help guys, I found an old breaker on ebay, not the best solution, but it will work for now until i can afford a service change or panel upgrade
  8. #8
    Join Date
    Feb 2005
    NJ
    Posts
    9,328
    Will it work?
    How do you know it wasn't taken from the swamps of New Orleans?
    I think you can't afford NOT to just buy a new one at HD, Lowe's, a local supply house, or even online from a retailer:
    Here's a list of supply houses in your area:
    http://searchbug.switchboard.com/bin...Waterbury&S=CT
    $3.95 @ http://www.okelectricsupply.com/cuhaweb.html
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    CELTIC
    ĦĦĦĦĦĦĦĦĦĦĦĦ
  9. #9
    Join Date
    Feb 2003
    Wisconsin
    Posts
    4,350
    Celtic,
    Yes, isn't it great to save money by purchasing from the used market. You save money, the space is filled, you attach the wire, and it does open and close all right. Not a problem. The space has been filled and you walk away content and the customer doesn't know the difference because they trust your judgement and expertise as that is what they have payed for.
    But, as you said, does it work? Can you be assured that it will protect in the event of an overload or short circuit?
    Is the electrician willing to gamble with a potential liability lawsuit?
    It's best to simply purchase one new that is uninstalled and has been calibrated at the factory sealed.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
