I am being asked to install a panelboard outside servicing an outdoor bar for a reasteraunt. They are building a basically a hut that will be open from all sides with no vertical walls to put a panel in. The only place to put the panel would be under the bar in the base cabinets.
My questions are as follows:
1. I know per 240.24A that the maximum height I can install a overcurrent device is 6'-7" to center of handle. Is there a minimum height it can be installed?
2. I know per 408.37 that I can install a panel outdoors (wet/damp location) as long as I meet 312.2(A) which says use a weatherproof enclosure and the proper conduit fittings. Is there any gotta's I should be aware of?
Any additional input is welcome.
Bookmarks
