Closed Thread
Results 1 to 8 of 8
Thread: How to convert tons to BTU
  1. #1
    Join Date
    Mar 2007
    Posts
    2
    According to the information I have, a ton is equal to 12,000 BTUs. Is this correct? To convert a BTU to a watt, do I have to divide it by 3,414? Thank you.
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    23,770
    1 watt= 3.412 BTU
  3. #3
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    23,770
    Here is a quote from another thread
    Quote Originally Posted by lowryder88h
    If you don't have all the spec's but you know the tonage, I use this rule of thumb for calc's. 1 ton = 12000 BTU
    1 watt= 3.412 BTU
    ex. 4 tons x 12000 BTU = 48000 BTU
    48000 div by 3.412 = 14068 watts
    14068 div by 240v = 58.6 amps
    Its not a percise science but it will get you into the ball park.
  4. #4
    Join Date
    May 2003
    Leesburg, VA
    Posts
    6,899
    3.412 or 3,412 boy that sure could mess up a calculation.
    Brian John
    Leesburg, VA
  5. #5
    Join Date
    Nov 2004
    Posts
    3,165
    Well, sort of:
    Let's be exact:
    1 ton of cooling is equivalent to 12,000 BTU/hour
    which is equivalent to melting a ton of ice over 24 hours.
    It is improper to equate power to energy! You should say,
    1 watt-hour (energy) = 3.412 BTU (energy)
    You cannot compute current draw this way because the AC pumps heat from one area to another. This is true whether you are heating or cooling with the AC unit. If you know the S.E.E.R. rating of the unit you can compute the power input. You can then compute the current draw if you know the PF of the unit.
    Do a search on S.E.E.R. for more.
    Don't mess with B+!
    (Signal Corps. Motto)
  6. #6
    Join Date
    Jul 2004
    Ca and Wa
    Posts
    1,462
    For quick roundoff results....3.5kW= 1 Ton
    a 4 Ton x 3.5= 14,000/240= 58 something
    This figure of course does not include seasonal EER adjustments either.
    rbj, Seattle...Safety is a Professional Courtesy.
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    17,465
    4 tons, 58 amps? Something seems a little off. Generally we find that 1 ton will have a load of about 8-10 amps. I guess that this figure represents lower ampacities due to the SEER rating.
    Rob
    Chief Moderator
  8. #8
    Join Date
    Nov 2004
    Posts
    3,165
    For the Record:
    Quote Originally Posted by infinity
    FYI, my 40 year old 3-ton Night/Day unit drew 19A @ 240V. Haven't checked the new one.
    Yes, you must consider the SEER number or your results will be grossly high.
    Don't mess with B+!
Closed Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
