Results 1 to 9 of 9
Thread: 4 point saddle
  1. #1
    Join Date
    Jun 2007
    Posts
    4
    4 point saddle
    what is the easiest way to do 4 point saddle bends
  2. #2
    Join Date
    Jan 2004
    Right here.
    Posts
    12,326
    There's only one way I know about. Just like two offsets, but allow for "shrink" on your first offset, so that your saddle ends up in the right place over the obstacle. Probably ought to think about getting a "Benfield manual" to put in your back pocket until these types of bends are second nature. It lays it all out, step-by-step.
  3. #3
    Join Date
    Jan 2004
    Right here.
    Posts
    12,326
  4. #4
    Join Date
    Feb 2005
    Wilmington, NC
    Posts
    4,500
    I thought the trend was towards a 3-point saddle.
    Saddles are something I never did get to master. I really admire someone that can bend them w/out fixing the length with a hacksaw.
    Lou (wannabe economist)
    If you relentlessly pursue perfection, you will eventually catch excellence.
  5. #5
    Join Date
    Sep 2004
    Durham, NC
    Posts
    5,500
    Lightbulb 4 Point
    I'll back it off of structure equal distance so I never have to come back to it, IE (future).
    2X for 45, 1.5X for 30, top of pipe to TOP...
    If you are even thirsty, you are two quarts low.
  6. #6
    Join Date
    Dec 2004
    Windsor, CO NEC: 2017
    Posts
    16,195
    Quote Originally Posted by hardworkingstiff
    IMO, three point saddles are trickier; and according to some I work with, they can be harder to pull through, than a four-point saddle.
    If I bend a three-point saddle and it returns perfectly into place after the obstacle on the first try, I know there is something else wrong.
  7. #7
    Join Date
    Jan 2004
    Right here.
    Posts
    12,326
    I bend a 3-point if I'm jumping over one pipe, but much more than that, it's a 4-point.
  8. #8
    Join Date
    Dec 2006
    Ohio
    Posts
    275
    Go here to download a PDF file on conduit bending courtesy of Mike Holt's website.
    http://mikeholt.com/documents/freest...ndRaceways.pdf
    Bob Kraemer
    RK Electric/Ohio Licensed Contractor
    "Some people are like Slinkies. They have no practical use whatsoever, but they still bring a smile to your face when you push them down a flight of stairs."
  9. #9
    Join Date
    Dec 2005
    New York
    Posts
    143
    I always found it easier to use center of bend when bendinng saddles
Posting Permissions
  • You may not post replies
  • You may not edit your posts
