Results 1 to 10 of 10
Thread: Underground conduit cleaning
  1. #1
    Does anyone know of a method, or preferably have experience, for cleaning partially blocked RMC - underground and concrete encased?
    More specifically several feeds (3/4" & 1") in a duct bank that have not fared so well after years of water, dirt, ash, and acid infiltration.
    Cleaning / Rodding / Roto-Rootering an existing conduit (a concrete encased conduit), ultimately allowing the new installation of a properly rated cable. Can it be done?
  2. #2
    Join Date
    May 2003
    Leesburg, VA
    Posts
    7,068
    We have used a plumbers camera to investigate the issues, and the pulled different sized mandrels through the conduit, sometimes it works sometimes not, Having the camera on a Snake was a big help.
    Brian John
    Leesburg, VA
  3. #3
    Join Date
    Feb 2003
    Illinois
    Posts
    23,316
    I have hooked a fire hose to underground ducts to flush them out, but you still need to use a mandrel after you have flushed them to verify that there is not a soild obstruction or a colapased section.
    Don
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
  4. #4
    Join Date
    Jan 2004
    Right here.
    Posts
    12,326
    I got a flyer a while back from a company that makes wire brush mandrels. That sounded like a fine way to get little sharp metal bits all through the pipe. Didn't appeal to me.
  5. #5
    Join Date
    Sep 2004
    Durham, NC
    Posts
    5,500
    Time is againest You
    Other than the fact that time and other chemicals are againest You,
    Coke-Cola for short terms situations, seen it clear out dirt cludes,
    desolve rocks, grout, works great for 1/2" - 3/4", never use more than
    a few liters and left it over night.
    If you are even thirsty, you are two quarts low.
  6. #6
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    5,590
    Quote Originally Posted by cadpoint
    I have herd of useing coke. We did use white vinegar on a short run of 1". Something like CLR might work but you would need to flush the pipe well.
    The 95% of people that you can't trust give the other 5% a bad name.
  7. #7
    Join Date
    May 2007
    Park City, Utah
    Posts
    55
    Diet coke & Mentos works every time.
    Hey! You set me up...OK?
    Jeff Weissman - Master Electrician
    Lone Star State
  8. #8
    Thanks for the replies. I never thought of coke, but i heard it works wonders cleaning toilets.
    I talked to mobile pressure washing company, they have a 1/4" high pressure snake, with compressed air or fluid, as another option.
  9. #9
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,467
    blockages
    I've seen the white vinegar work well on grout.
  10. #10
    Join Date
    May 2007
    Central Texas
    Posts
    147
    I carry a shop vac with leaf blower as well. Works on most also easy for getting your string lines through and blowing water out.
    Ask the experienced rather than the learned.
    LMNelectrical.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
