Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: crimp on terminals for stranded wire
  1. #1
    Join Date
    Jul 2007
    Eatonton, Georgia
    Posts
    1,159
    Is it a code violation to use crimp on terminals to connect stranded wire to a recep or switch ? Thats the best way I know to get a good connection especially with # 10 stranded. I saw the post on different way to get the strand wire to hold on grounding screw, but no one mentioned the crimp on terminals.
  2. #2
    Join Date
    Jul 2007
    Flagler Beach, FL
    Posts
    49
    we use stake-ons as a rule for switches and receptacles and ground screws. i agree it makes for a fine connecting using stranded wire.
  3. #3
    Join Date
    Feb 2005
    NJ
    Posts
    9,328
    Not a violation ...costly to install, but that's another story
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    CELTIC
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    An error on your part does not constitute an emergency on my part.8-)
  4. #4
    Join Date
    Mar 2003
    New England
    Posts
    13,287
    Arrow
    Or you can just buy backwired devices. Not the cheap residential kind but with the screw pressure terminal. They only cost a little more if you are using all stranded wire and they terminate much faster than "sta-kons" or wrapping stranded around a terminal.
  5. #5
    Join Date
    May 2007
    West Virginia, USA NEC: 2008
    Posts
    1,971
    Quote Originally Posted by jetlag
    I saw this comment on another thread and I will reiterate my opinion, The crimped terminals with a ring or flange is what I use. A properly crimped terminal is highly reliable and easy. It's all I use for stranded.
  6. #6
    Join Date
    Jul 2007
    Eatonton, Georgia
    Posts
    1,159
    Thanks for feedback
    Glad the crimp ons pass code. I cant seem to find the hook end in a #10 so I get the ring type and cut a slot and spread then compress around screw. The open end fork type dont hold well at all. Yes Im familiar with the compression back wire recep. , and I keep some for special times like when wires are to short to get around side screws easily or when need heavy duty 15 or 20 amp. These are quite expensive in $ 3 range so can get whole pack of crimp ons for that
  7. #7
    Join Date
    May 2007
    Posts
    1,971
    I use the open-end forks that have the ends of the forks bent to provide a good grip. They don't slip off.
    Go to http://order.waytekwire.com and type in part number 32720 in the search box to see what I'm talking about.
  8. #8
    Join Date
    Sep 2004
    Ohio
    Posts
    756
    I thought the code said you had to use crimp-on connectors on stranded wire, but I have been looking and I have not found it yet.
  9. #9
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,150
    Quote Originally Posted by guschash
    You won't find it. Device terminations types are listed by the manufacturer. Typically any device binding screw can terminate up to a solid or stranded #10 AWG conductor.
    Rob
  10. #10
    Join Date
    Jul 2007
    Eatonton, Georgia
    Posts
    1,159
    Crimp on solid ?
    Quote Originally Posted by infinity
    Had another electrician to tell me cant use crimp on terminals on solid wire, and I didnt doubt him because they dont hold well at all , can twist terminal around easily after crimping, so I only use crimp on on stranded wire , they hold very well
Posting Permissions
  • You may not post replies
  • You may not edit your posts
