Thread Tools | Search this Thread | Display Modes |
#1
Hello Everyone,
This is my first time posting and using this place. My boss told me about it and so far the site is great. I am running under cabinet lighting in a new construcion. I was thinking of running the wire from the switch to each cabinet location and stubbing it out of the wall at a heigt certain to be inside the cabinet. And then I am thinking of coming after the cabinets are installed and putting a remodel box with an outlet in, at each of the locations the wire was stubbed out. I will be installing those round lights with cords that have plugs on the end, and I would just drill a hole in the bottom of the cabinet and plug the lights in the outlet. Is this the best way to do it? Or is there something easier or more simple? |
#2
Quote:
Puck lights in general have a lousy reputation for durability, or lack thereof. If your boss will allow it, I'd highly recommend NM directly into small flourescent fixtures instead. I have done an in-wall (i.e. the fixture wire is inside the wall) installation of Xenon puck lights in my own home. Fixture wire goes up to the attic where there is the j-box for the transformer. Wouldn't do it for someone else though just because once the pucks disintegrate it will definitely not be a DIY job to replace them. |
#3
Quote:
Hello, I'm going to be adding (6) under cabinet lights to a kitchen remodel and would like to know about the different options also, the way I've done them is like tallguy NM directly into small flourescent fixture. I was able to hide most of the wire but is this the only other option and is this code compliant???Thanks, JB
__________________
JERRY-Lighting & Electrical in So Cal... *Please be advised that all post and replys given are my opinion only! Any feedback, opinions, suggestions or corrections are GREATLY APPRECIATED... |
#4
Quote:
These lights you are talking about are made for DIYs, not electricians. Find a better quality lighting fixture.
__________________
Bob |
#5
Quote:
__________________
#6
Quote:
If you search this site for 'Puck Lights' you will find very unhappy comments. Pretty much any fixture that comes with a plug already connected is not designed to be installed in compliance with the NEC. You can't conceal or attach flexible cords to building surfaces and remain in NEC compliance. You need a fixture made to be hardwired with NM, MC, AC or FMC etc.
__________________
Bob |
#7
Another thing about puck lights- they generate a lot of heat. So much so that a jar of peanut butter or a bag of Hershey's kisses will melt inside the cabinet above it. They all contain a large plastic component which will discolor and become brittle over time.
#8
Quote:
__________________
#9
Check out Sea gull lighting.com. They have alot of nice under cabinet lighting. I have install Xenon task lights and I like the light it gives out plus you can hardwire them.
#10
mount your transformer in the bottom cabinet i put a receptacle beside the dishwasher/disposal. the run 18-2 up to the bottom of the cabinets , verify the hight with the carpenterthen you can just staple your wire to the little lip on the cabinets.
but like its been said pucks are not very reliable but if the ho is set on them id go for it. |
| Display Modes | |
