Results 1 to 7 of 7
Thread: Transformer/ Main panel
  1. #1
    Join Date
    Jun 2006
    Posts
    174
    Hello all
    I have a 45kva transformer that secondary wired terminate in a 150amp main panel breaker. In that panel the neutral and grounds are seperated. Shouldn't they be bonded together after a SDS? I say yes but my foreman disagrees...
  2. #2
    Join Date
    Oct 2006
    Baltimore, MD
    Posts
    3,161
    Yes. Bonded at the transformer or first disconnect. 250.30(A)(1)
    John from Baltimore "One Day at a Time"
  3. #3
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,896
    transformer grounding
  4. #4
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    As John pointed out it's either bonded at the transformer or the first disconnecting means, or in some cases it can be done at both.
    I always bond at the transformer, I think it keeps the panel cleaner looking.
  5. #5
    Join Date
    Jan 2005
    Posts
    937
    if the grounds and neutrals are separated at the 150 amp panel the bonding jumper would have to be at the transformer
  6. #6
    Join Date
    Mar 2006
    Tampa Florida
    Posts
    8,009
    If you dont how will it clear a fault ?
  7. #7
    Join Date
    Feb 2006
    Pa.
    Posts
    2,021
    Quote Originally Posted by Jim W in Tampa
    You need to open the transformer or panel and look for the jumper.The GEC should also be installed where the jumper is made.
    Rick
Posting Permissions
  • You may not post replies
  • You may not edit your posts
